DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Jd Humanoid Robot Controlled By Kinect
This is a video of JD being controlled by a Kinect, I still need to to fix some discrepancies.
Only head, arms and grippers are being controlled.
I have the legs ready but i need to figure out away to secure JD when he loses the equilibrium, it's very difficult to keep him safe if you make a wrong move.
fishing lines ? more ideas ?
As the video shows You making motions live in front of Kinect. The servos move to follow your motions live. Could it be possible record your live performance and play back that motion ( not live)?
You could write a short ezscript that loops every 100ms and saves each servo position to a file, separating each position with a comma
Simply make another script that reads back the file and sets the positions.
Well this would be amazing. About 101 new uses if someone can make this happen! Extending uses for EZB!
Will,
Its funny everything started because i was lazy and i wanted to create jd movement actions.
I'll create another video to demo the record & playback
Crazy idea that is probably more work than it is worth, but an EZB project is essentially an XML file. Could we write the file of servo positions and timings as an set of AutoPosition frames and actions that could be imported into an EZB project?
That would allow for simple visual editing of the routine after it is recorded.
Ha ! I've been throwing this idea around in my head for sometime. I seriously have 101 really really cool ideas for using this. This is basically motion capture.
#15
Any luck with recording and playback of motions?
