well i finally got the guts to try to solder on the ezbv4 i solder a mouth led straight on the ezb. use a bride led
— Edited
11 Participants
UBTECH Alpha Servos UBT-12HC
— Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping.
hi tony
its actully round.
hi @nomad18.08 so you just drilled a hole? Do you have a small resistor wired into the red line?
hi tony
yes inside the ezb.
pics
Thanks @nomad18.08 Would it be a 1K ohm resistor?
hi tony.
i make a pic cause i dont have knowledge about these things.
here is the pic
Thanks @nomad18.08 ! Now I see how you got the neat black trim around the mouth
it clicks together and the led stays in place. the little ring has two sides.one side start the treath in the begin off the ring for , thinner plates.the other side start a little further for thiker plates. i melt the hole whit a little iron screwdriver and then whit a little round vijl, make it bigger.
