Pushover icon Pushover — Send robot status alerts to iOS, Android and Windows via Pushover.net. Configure User/App keys to notify on low battery, stuck or task events. Try it →
Jd Not Working
hello I'm a jd owner and my jd and has not been working very well. when i first got it we were given parts because the on we got did not work and we thought that the problem was solved. my dad took it to his work to see if someone could do calibrate it for us. I thought that it worked but it would not walk straight or turn correctly. so I decided to re calibrate it but when i did it would all ways fall over when walking. please help i do not know what to do.
tristan
when you calibrated your servo's.do you put them in port D0 correct , the bracket iff needed.and then pull the wire out D0 and put another servo in. D0 whithout powering off or disconnect the ezbv4.when all done save, the web page.and then you do the video as chown above from dj. when you open the ARC you have to choose that file from fine tune.
@Tristan..... Here's the thing about servos (and most other stuff made).... Not all are created equal..... When they are manufactured the manufacturer has a set minimum tolerances for them.... This means as long as they meet a certain standard then they are deemed good.... This also means you (all of us too) are going to get some servos that are stronger than others.... So for example if your JD seems to always walk left when he is supposed to walk straight (even after he is correctly calibrated and fine tuned) the servos in his right leg might be a little stronger than the ones in his left.... This is what I would do.... Mix up the servos.... Take some servos from his right leg and swap them with some servos in his left.... or take servos from his arms and put them in his legs.... Bottom line is what you are trying to do here is even out how he walks by not having all the strong servos on one side of him....
rr
iff you mix the servo's dont you need to do the fine tune and call all over again?
Yes probably, but fine tuning only takes a few minutes.... isn't it worth it if it gets his robot to walk straighter?....
i know avery robot walks a little to one side after a meter orso. but you sure have a point .i would love to see a video from tristan robot, in action.good for learning.
Thank you all for helping me to get my robot to work. it is walking normally because of you people thank you very much
