Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
  1. Do you have the latest ARC?
  2. Are you using the most recent JD project included with the latest ARC?
I just recieved jd. I am assuming it is the latest
DJ meant ... do you have the latest version of ARC software downloaded....?
Also, do you have your JD assembled correctly? All servos should be at or close to 90 (as close to as possible) when JD is in a standing position....
I tried unplugging them and turning them around but it only worked for some of them. JD didn't come with the snap on piece for the right knee. They sent me a piece replace it and it never worked or moved. the both elbows and claws do not work as well and the most up to date software.
Not just the calibration tutorial but all tutorials.
Completing all tutorials will help you enjoy your EZ-Robot.
This is the video of jd not working.
