Oculus Quest Robot icon Oculus Quest Robot — Immersive Meta Quest VR control for Synthiam ARC robots: stereoscopic camera view, map servos to hands/controllers, plus built-in remote desktop. Try it →
Jd Will Not Turn On
Today one of my JDs in my class would not turn back on. I unscrewed JDs back to double check all connections in his body and everything is intact. JD never indicated that it was on low battery after all JD was charged overnight. I've adjusted the female pins as shown in the video even though I didn't think that was the issue. This JD worked early in the period and sporadically stopped working. In addition to that, the power button is flipped upside down (this is how it was when we opened the box but it did not affect its function). Has anyone experienced this problem before? Regardless what should I do?
Thank you for your response in advance.
Turned out to be the EZB. I was sent a replacement. Thank you all who helped !
