Which plug is it? I want to remove Jd's speaker.
Deborah Crain [email protected]
Ultrasonic Collision Detection
— Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling.
JD's speaker is a pressure fit in the case. Simply remove the speaker from the ez-bs case. If you want to install another speaker, see the breakout hack tutorial.
Which plug is it?
It is not a plug. you will need to remove the EZ-B from JD, open the EZ-B case with a screwdriver, and remove the speaker from the bottom of the case.
This thread: https://synthiam.com/Community/Questions/7911 has photos and instructions for adjusting the contact springs when the speaker doesn't work. You could use that as a guide for removing the speaker instead.
Take a Philip's screw driver and remove the 4 screws in the ez case... pry out the speaker from the bottom half of the case then screw the case back together. .. That's it.... your JD will be quiet now...
Send a picture of the speaker,I don't know what the speaker looks like.
Dont be lazy, search. Dohh.
Flip the ezb upside down... you can clearly see it in the bottom case... BTW Why did you start multiple threads for the same question?
@deborahcrain The thread I linked to in post #4 has a picture of the speaker with the case open.
@proteusy please be nice to the noobies. We try not to be a "search before asking" type of forum, particularly because the search engine here is not very flexible. (we are a "take the tutorials before asking" group because they are very good and answer 90% of questions, but this one isn't answered in any of them).
