Notepad icon Notepad — Notepad for ARC: store project notes and connection details in a themed window Try it →
#17
It's a surface mount but I don't have a NTE or TE part number
#19
The part number is not visible, EZ Robot will need to give you that info.
No sir but thanks. This subject really needs the attention of an ez robot engineer which I believe is Jeremie
#23
Jeremie is the only one who can reliably answer this query, await his response.
That said, you want to also find out why the component went otherwise it'll just go again.
#24
Just as an fyi reverse voltage was not applied. The machine was moving around under control , stopped during a forward movement and proceeded to let magic out.
