Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
Jerky Servo Motion
I started working with a JD robot a couple of days ago. I am looking to create fluid motion from pose to pose.
I am programming the motion via the Script Collection (Python). This is resulting in a relatively smooth motion at a constant speed, but I would like to create acceleration or motion profiles to make the motion look more lifelike. Below is my python code to wave
shoulder = 3
bicep = 4
elbow = 5
grip = 6
def moveServo(port, pos, speed=0):
  Servo.SetSpeed(port, speed)
  Servo.SetPosition(port, pos)
def wave(iter=0):
  moveServo(elbow, 50, 1)
  moveServo(grip, 70, 1)
  moveServo(bicep, 70 if iter == 0 else 110, 3)
  sleep(400)
  moveServo(elbow, 0, 1)
  moveServo(grip, 90, 1)
  moveServo(bicep, 90, 3)
  sleep(400)
def armhome():
  moveServo(elbow, 90, 2)
  moveServo(bicep, 20, 2)
  moveServo(grip, 90, 2)
  moveServo(shoulder, 90, 2)
moveServo(shoulder, 0)
moveServo(elbow, 0)
moveServo(grip, 90)
moveServo(bicep, 90)
sleep(1000)
wave()
wave(1)
sleep(1000)
armhome()
sleep(3000)
I have also messed around with creating motion in a "Robot Skill" via a c# workflow. I've noticed the motion from servos in this is very jerk though. Below is a snippet of my code from that:
private void button1_Click(object sender, EventArgs e)
   ARC.LogManager.Log("clicked the button!");
   ARC.EZBManager.EZBs[0].Servo.SetServoPosition(EZ_B.Servo.ServoPortEnum.D0, 10);
   Thread.Sleep(1000);
   ARC.EZBManager.EZBs[0].Servo.SetServoPosition(EZ_B.Servo.ServoPortEnum.D0, 170);
My questions are:
  1. Can you adjust the speed of the servos with numbers with decimals in either python or c#? i.e. 1.5 speed instead of 1 or 2?
  2. Is there a better way to control servos in C# such that the motion will be more smooth?
  3. Are there some other ways to control the servos which may result in more fluid, life-like motion that I haven't thought of?
Thank you in advance.
JD Humanoid by EZ-Robot
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
Thank you for the help! This works
