ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
Jittery Servo Movement
Hey there, I am having an issue with my robots movement here. I build a litte Lego robot consisting of 10 micro servos, they are supposed to have a 4.8Volts input.
https://www.servodatabase.com/servo/towerpro/sg90
But since I just bought a power supply with a fixed Voltage output, I am putting 6Volts in for this is as far as I can lower the Voltage on this particular power supply...they should be able to take up to 8.4Volts I read!
I made an animation cycle using the AutoPostition in ARC and the movements are pretty smooth...but after a little while the whole motion becomes choppy and erratic.
The power supply is a 7.5v 20 amp switching supply that I found with the help of @SteveG, so the servos should be getting enough Amps!
What could be the problem? I had some Wifi connectivity problems with the EZ-B lately...could it be a problem of data transmittance, or is this some issue with AutoPosition in general?
My board is not having any brown outs so I guess power is supplied at any times!
Where would I start searching for my mistake here?;)
#17
DJ, Thanks very much for the explanation on the timing settings in the AutoPosition control and scripting. I've been playing around with these settings and it's been hit and miss. It seems like just luck I've been able to smooth out my movements but I haven't really understood what I was doing. Your explanation really helps clear up a lot of my confusion. I'm really looking forward to the documentation and tutorials you mentioned. This will make things much more understandable for me and and help to get better results.
#18
So I made some testing on my issue here and I found out that the channel the EZ-B and my router were using are cluttered with other networks, so I put them to a different one which seems to be not saturated with connectivity! Also I experienced that my servos are getting jumpy at random points within the animation...it could run well for a good while and then all of a sudden it acts weird, servos are getting jumpy and they are falling back to normal shortly after!
Because of the randomness I was concluding it could be more of a data transmitting problem rather than one from within the Auto Position?
Or could it be that DELAY, STEP or SPEED are interfering and are causing problems at random stages within the animaton?
I tried Client and AP mode with the new channel I found, I am sort of thinking it improved the jumpiness a little, but since it is all random I cannot really tell!
It helped my EZ-B not being kicked out of the network though!
How could I test this better? I was thinking to just make a simple animation just an up/down movement with two servos and have it running for a while...I am a bit stuck here right now!
confused
#19
Great news, and I think your plan to find this issue is spot on. Having only a couple of servos running will allow you to see if power is the issue or not. It will also let you see if the network is the issue. If this is still happening with only a couple of servos running then it is probably still a network communication issue I would suspect. If it doesn't happen with only 2 of them, I would think that it is a power issue.
Does your robot also have a ping sensor? If it does, you could try to flood the communications channel by running a script that queries this port with a very minimal sleep step while running the limited animation. If the robot starts experiencing similar issues, it is probably your wifi network still. If not, you know that your wifi network is now good and can start looking in another direction.
#20
Hey, this sounds really helpful...I was thinking that it would be great to have a tool checking the Wifi connectivity, this could be a good addon to the existing EZ-B info panel so one could check if there are connectivity gaps while talking to the EZ-B!
I do have the Ultrasonic Distance Sensor for the EZ-B, would this help to run the script you mentioned? Could you help me writing this script, so I can be sure it works properly?
Thanks for pushing this to the right direction, hope it can be solved soon!:)
#21
You could just add a ping control and set the settings to something like...
This single control might not flood the channel, but a couple will if setup with a small interval.
#22
Cool! I will try to get this set up right now! Thanks man, this is really really helpful!:D
#23
Hmmmmm, I dont know if I got you right here....so I setup 5 of those Ultra Sonic Distance Controls with a 100ms Interval. I put a simple up/down motion to only one of my servos, but nothing really happened!
The sensor script does not seem to be making any difference to the animation running and the animation is also still getting choppy at random times!
I am running the EZ-B on Ap mode and my Laptop sits right next to it! I am using a Wifi channel which should be free of interferrence and I even removed the Power Supply from my desk!
Any other ideas on how to test for connectivity problems or did I make a mistake setting up those ping controls? eek
#24
The ping controls would only help to flood the communications channel if the 2 servos were working without any issue. This would help to cause the situation to exist if it were an issue with flooding the wifi channel.
So, with 2 servos running, this is happening? I suppose it might be possible that the servos are interfering with wifi but I really doubt it.
Try moving the robot further away, like maybe half way across the room and see if the anamation has an issue with running only 2 servos and no ping sensors.
