Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
@DJ just a thought, is it just as simple as having the ezb check the output of the reciever for a "high" or "low" when connected to an adc port?
Apologies if I am talking rubbish. :-)
No, infrared is a pretty lengthy discipline. You will always detect IR, because it's all around us. Specifically outside, which is why you never see IR devices work outside. Although it was funny when I read this ignorant article about a farming robot. Which is a little off topic, but made me laugh at how ridiculous it is...
  1. The claim is the robot can see other robots by an IR detector - well IR doesn't work outside in the day because the sun literally bombs us with IR.
  2. It can "avoid obstacles" apparently with a distance sensor on top of it's head! ha, on top of it's head - so I guess it can only avoid things that are as high as it's head Shrug
  3. my favorite, it apparently has a magical seed sensor that can detect seeds. Wow, that's a new type of sensor I've never heard of. Seed sensor. I wonder if it can detect eggs too, might come in handy at easter:P
Anyway, that's rubbish - if you needed an example:)
If you want an IR beacon, I would build your robot on top of an iRobot Roomba.
-OR-
get this: Pololululululu IR Beacon
Oh I see :-)
Pants, back to the drawing board then.
Thanks for taking the time to answer, hope your having a great thsnks giving.
:D
Thanks man! Take a look at the polululu sensor and see if that would work for you
