PTI Lidar Plugin icon PTI Lidar Plugin — Pineapple Technology Industries Capstone plugin adds a secretive LiDAR unit to ARC for distance measurement. Try it →
Just Received My Rover 5 & Etc., But.
When I connected the Rover 5 to the board, the tracks continuously went in one direction. I tried controlling them in the ARC control setup, but they still continued to move in the same direction without any change. I have the two servos jumped to the EZ-board. Black to ground & red to 5v....am I doing something wrong?
The Rover 5 should be equipped with DC motors, not servos... in order to control them from the EZ-B you require an H-Bridge motor controller like the one in the store: 2.5 Amp Motor Controller
Yea disconnect that from ez b , it draws 4 times what ez boards made to put out. Gunner is right. You need a l298n h bridge motor driver. A. Bridge allows motors to go forward or backwards and takes the load off your ezb microcontroller.
Thanks for the help guys. Much appreciated.
No problem , post your build in the projects section. We would love to follow your progress. - Josh S.
