Hi all new here im new to ezrobot and more used to arduino my question is will the EZ-B V4 controller run the JX PDI-6221MG servos? as they are 330hz and arduino servo.h cant run them. so looking at jumping on board with the ezrobot crew. many thanks for any advice.
I can confirm it will run them as I use one in my inmoov build.
thank you very much for that i can now go ahead and order the ez-b now thanks again
