EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Resolved Resolved by Rich!
L298n Motor Sheild Scripting
Rich and Friends,
Got a new l298n H bridge and it works great but I have a few questions.
  1. I need to know how to call a script using a button push
  2. I know there are some examples of the scripts out there but can some one point me in the right direction :0
I was also wondering if any one has seen the e-zb respond in weird fashoins like this example.
I got my serial Sabretooth Movement Panel and 4 digital on/off
I can turn the digitals on and off and use the Movement Panel but when I go back to setting the digitals on and off the wheels (Controled by the sabretooth) start moving the bot in circles.
Also when I power my bot on one of the arms will go up on its own.
Before I am even conected to the blue tooth.
I am going to try and redo the firmware but if anyone has any other ideals I would appreciate it.
Thanks again,
Michael
Thanks Rich we are all working
Hola buenos dias, por este medio me gustaria obtener mas informacion acerca de la tarjeta Arduino, quisiera saber todo con respecto a ello, todas su caracteristicas, en si todo... de ante mano Gracias Feliz dia
@Wilson,
You wouldn't mind using "Google translate" to translate your post next time?:) We do have a very diverse user group that speak a number of different languages but english is the common language that we try to use as a community to communicate with eachother. Thanks!
Where you inquiring about an arduino interface board that connects onto the EZ-B or just a general Arduino board like the UNO?
