MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Resolved Resolved by Jeremie!
L698 Motor COntrol Alternatives?
L698 Motor Control Alternatives?
I've used the L698 motor controller with IoTiny for a few projects, but its form factor is a bit big and has a somewhat awkward design.
As I continue to be a beginner, are there alternatives to the hbridge that are compatible with the IoTiny? Perhaps something like an MX1508 https://www.techmonkeybusiness.com/using-the-mx1508-brushed-dc-motor-driver-with-an-arduino.html
Or some other brushed dc controller with a smaller form factor?
Thanks.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
I'm not familiar with that model, is a cheap clone ?
I' would rather focus on the specs versus if is visually apelative or not.
As beginner you should rely as much as possible on ARC's supported hardware, unless you are familiar with scripting and / or ARC's custom movement control.
You missed the most important detail: the motors specs, if you plan to use one or two motors.
That motor driver would work with the regular HBridge Movement panel. But it will not work with the PWM HBridge Movement panel. This means you will have no speed control. That hbridge does not support speed control. It's either on or off full speed. If you want a smaller hbridge, simply use the internal servo PCB. A servo pcb is ah hbridge.:)
@DJ, looking to the existent information the IN1 is forward PWM, IN2 is backward PWM. You have speed control, but is not compatible with ARC HBridge control.
Thanks for your input fellas.
I do prefer using 360degree servos as motors as they easily work with the movement panel.
However, I was looking at SMARS open robot project (https://www.smarsfan.com/) that uses an Arduino, two 3-6v small motors, motor shield and other electronics. It looked like fun. So, I wanted to use an IoTiny instead, but the Hbridge was too big for the 3d-printed body that it uses.  I'm still new to Fusion 360 so modifying the body to accommodate the bigger hbridge form factor isn't in the cards.
I'll stick with servos for now.
Thanks.
#5   — Edited
Yah - servos will be great. But you can also wire the servo PCB to the existing motors and use them as hbridges. Remember, the electronics in a servo is really just an hbridge.
Given the size of the iotiny, i think an lm hbridge would fit next to it. If all else fails, a bit of duct tape never hurts:D HAHA
And you can still find room to mount the camera on the front. A robot without a camera isn't a robot:P
#6   — Edited
Hi I hope all of you are ok
I use the L298N Motor Drive Controller Board Module Dual H Bridge DC Stepper on Amazon - it was only 12.99
