EZ Chart icon EZ Chart — 4-series bar chart for real-time sensor comparison in ARC; set titles, values, RGB bar colors and conditional coloring via EZ-Script. Try it →
#17
That won't work with the EZ-B. Well, it technically could if you were to spend a few weeks porting arduino code over. But then you end up losing 16 I/O pins just for the LCD. There are only 20 i/o pins on the ez-b, so losing 16 is a lot.
the tutorial page on here specifies that it is best to use Serial Display. You can find the tutorial page by clicking Tutorials on the top menu. Or here is a shortcut for you: Serial LCD Displays
#18
DJ, Did you ever get your i2C LCD?
#19
@bookmaker yup. it's on my list to look at:)
