Hey guys,
I tried to use the original LED that comes with the WALL-E U-Command with the EZ-B, but the LED does not turn on (using digital ports).
Should the original LED work, or should I use another type of LED with the EZ-B?
Midi Control
— MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes.
Hey guys,
@ jstarne1
Hi, do you also experience flickering when changing the intensity of leds that are directly hooked up on the i/o ports?
If you are noticing flinkering while using PWM - you can probably fix that with a cemaric capacitor. It because there is practically no resistance in an LED, you could be visually seeing noise
cool! Thanks, ill give that a try. You guys are up late and must be drinking lots of coffee, I hope work is going well.
