Labview 2015 Sdk Integration
Hey,
So I've been working with the EZB SDK with VB C and C++. I got the hang of it and know most of the functions/how to set up. I'm working with some fellow colleagues on integrating the EZB with a feature extraction algorithm written in labview. However, for some reason I cannot reference the EZB.DLL into labview and get started! I know its a .NET type but something tells me it has to do with 32/64-bit compatibility issues. Could this be the case? We do have some labview code that controls an EZ-Rover and it references the dll properly, but that was written in LabVIEW 2013. Do we need to downgrade or change compatibility?
Thanks in advance!
Do not create a new thread on the same topic. Here is the content of the duplicate thread, which has been deleted.
Hi,
I recently posted a thread regarding the usage of the EZB SDK in Labview 2015, however, I'm still having issues using it in my code. I'm using LabView 2015 - 32 bit on a windows 7 -64 bit system. I have the latest .NET distributables downloaded. I have also tested the dll on a C++ program in VS2015 and it works fine. Whenever I create a .NET reference constructor in Labview to reference EZ_B.dll I get the following error: "An error occurred trying to load the assembly" (See image)
However, referencing other files, like aForge.dll and EZ-QRCode.dll work fine (See second image). When working with LV2015-64 bit, all the dll's had the same error, as expected.
Is this an issue that should be put up with National Instruments or is there something I could do from this end?
Thanks!
@anas9011:
What EZB's features you will need/use with LabView ?
I recommend the OP uses the mono dll instead of the sdk. Considering they're so similar.
The sdk only has vision stuff that you're probably going to do in labview anyway. If needing the sdk for vision as well, I guess the question is why is labview being used and not visual studio?
Visual studio is much faster
@DJ,
That was my direction, if they say no video, Mono version will work.
I suspect LabView is doing .net reflection on the EZ_B.dll to provide a "Wizard" view of the dll, and that's not possible with the EZ_B windows version.
@ptp I will be using very basic commands that involve servo movement. Basically moving the robot around. @djsures One of our lab members wrote a very robust feature extraction algorithm in LabView and converting it to C++ or the like would be very complicated and time consuming. I personally prefer VS over LabView. Let me go over the mono and see how that works out.
@anas9011,
regarding your setup:
are you using analog servos or digital (dynamixel) servos ? do you have a EZR kit (JD, etc) or is a custom setup ? do you need the EZB camera feed ?
#15
@ptp @djsures I just solved it....I really hate it when I do stuff like this. The LabView VI and the SDK folder were in the same folder, but the DLL's weren't. For some reason I just decided to put all the DLLs and the VI in the same folder now. Now I got all the functions to load.
FYI I really appreciate you guys taking the time out to help me. Big Kudos. My LabView programming logic got a bit better now:P Thank you guys VERY much.
#16
ah! that maekse sense:) great to hear it's working! I feel silly for not suggesting it - guess we all overlook the simple solutions sometimes
