PWM Slider icon PWM Slider — Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection. Try it →
Last Trouble Of Voice Recognition ?
hi DJ ! I try many thing about Speech recogunition . And i would like to my present trouble about voice recgunition . i made a original words in japanease to recogunize the voice recogunition. Then , this time Speech recogunition only respond Enable phase and command, and Disable phase and command, but eventhought the same phase is using, normal phase and command did not respond ! ? Could you tell me the reason why this things happen?
GOJIRA57 From japan. stress stress stress
Dear DJ ! Dear DJ !
Thank you very much for your advise. After your advise, ? train the speech recognition, several time, but condition was not change. So ?would like to explain my speech recognition detail . Basicaly ,speech recognition is working ,Because of the following reason. First, I registere the word " robot" this word is simple enough to recognize. And adjust mic level and so on.... following windows tutorial. 1. ?n debug windows show the word "robot" . so I think ARC Recognize the word. 2. speech recognition windows , first I wite enable phase " robot" and write command say("robot , good") then save and close window. 3. speak word " robot" debug windows show "robot" and also, speech recognition windows shows enable and computer speak command " robot good". 4. so for is good. But problem is next step, open speech recognition 5. windows and change config erase enable phase " robot" and erase command say("robot , good") . 6. next I wite normal phase " robot" and write command say("robot , good") then save and close windows. 7. speak word " robot", debug windows show "robot" this is ok, but speech recognition windows shows nothing and did not speak command " robot good". 8. my question is why enable phase and command is ok But normal phase " robot" and command did not? I think this was not training problem. System recognize voice...
    Sorry  my  bad   english  and to trouble many time , could you advise my question ?
Sorry to trouble many time , could you advise my question ?
Can you post your .EZB file to the EZ-Cloud for us to look at?
hi DJ ! I tryed to training only word "robot" using word pad 20 times , after that finally (normal mode repond ), then i registrate "?????" typical japanease greating, at that time even thought i did not training but soon speech recognition normal mode repond , i think in japanease windows 7 os i should have registrate japanease word from begining
thank you DJ and Lumpy , i charange the next step of ARC
Great to hear of your success:D
