Auto Position Movement Panel (Gait) icon Auto Position Movement Panel (Gait) — Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control Try it →
Lawnbot Build
Hi All
I have begun to gather all the bits needed to build a Lawnbot 400 as published in Make magazine.
I am looking for wheel or drive motors. I think the raring needs to be 200- 400 W. I have some alternates, but do not have matched pairs.
I am in Central Ab and would prefer a domestic supplier, but will go further afield if required.
Thanks in advance, Cam
Thanks PhG.
These motors look like a very viable alternative as they have mounting holes and a sprocket already supplied. Making a final drive would be easy - just find a matching sprocket type with more teeth. Might take some juggling to get the speed sorted. I think max travel speed should be 4 mph or about 6 kph.
Did you find these on Bangood, or mfr direct? Any chance of a product # if from Bangood?
Thanks in advance. Cam
Hi Cam,
I got the lager motor from eBay. It's actually from a eBike conversion kit. They sell them in different voltage/power ranges. And these days they're quite cheap.
Here are some examples: eBay: e-Bike conversion kit
I'll have to look into the details on the smaller motor. It's identical to the one Dave is showing in his video, but mine comes with a sprocket. I have another one like Dave's with the pully still attachted somewhere in my shed in the back yard. It's been harvested from an e-Ped. Now that the winter is almost over I'll spend more time in my shed and hopefully get back to you with pictures of the drive with chain and sprocket.
Greetz,
Philip
