Key Control icon Key Control — Assign scripts to any keyboard key (press/release), map arrow keys to movement controls; activates when the control has focus (green). Try it →
https://synthiam.com/Tutorials/Hardware.aspx?id=13 is a good place to start.
Serial lcd's are much easier than i2c. Avoid i2c if you don't know much about it.:)
Connect power to the LCD. And also connect a digital wire from the EZ-B. it's easiest to use a peripheral cable.
Then in EZ-Script, you can use the SendSerial command. The syntax and help are displayed in the script editor manual:)
