Let me ask: when I program the servo with EZ-Script language, I need to program Blockly and can guide me how to create them?
tu2002
Joystick (Direct Input)
— DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback.
Blackly is much easier than ezscript, so not sure how you can do one without the other. However, I recommend following the great Blockly and programming tutorials that ezrobot made called The Robot Program. Look here: https://synthiam.com/Tutorials/
Just visit that link and select your ezrovot product and get started using it.
If you’re using other hardware like arduino, the usage is quite similar so it’s cross knowledge with ARC.
