Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
Hello Yes ARC can do that easy:)
You can download ARC for free and play with it no need to have an EZ-B to use ARC I spent most of my time playing with it with out powering up my robot and I get it to say all kinds of things using the Say("$Your_String_Here") command.
I LOVE IT Its just to EZ some times its hard for me to get it to shut up;) lol
Try this...
$value="I am a robot"
SayEzb{$value) #out the EZB4 board speaker
Say($value) #out through your PC speakers
Or a more complex example...
$temperature = HTTPGet("https://192.168.0.100/temp.cgi";)
$voltage = GetADC(ADC0)
SayEZB("Good morning, it is " + $time + " it is " + $temperature + " degrees outside.")
SayEZB("Your battery is holding " + $voltage + " volts")
Wow! Thank You for the assistance! That was quick!
Any idea on how to have the text being sent to a second EZB's audio output?
As far as I can tell, the SayEZB script command only works on board 0 like Movement Panel commands.
If you have pre-recorded utterances, than the SoundServoEZB can be defined to use different boards and you can trigger them with ControlCommand script commands.
Being able to direct speech to a particular board (or defining a Movement Panel to something other than board 0) would be helpful on larger bots where one EZ-B needs to be in the body to control wheels but another can be in the head producing speech.
