Linear Actuator Ezb Script
I have looked on the community and don't seem to be able to find a simple answer on how to control a Linear actuator.
What I am doing is making my Tin Man robot upper body rise up or down on command. I have a 12" actuator. It has two wires. To change directions you reverse the two wires. I would like to use one half of a Hbridge motor control. The motor control I have is a two in one Hbridge. I thought of using a movement control but I already have one controlling the wheels.
The linear actuator is moved by a 12v dc motor. I will power the actuator with 12v from my two twelve volt lead acid batteries. Do I just control the Hbridge with servo code. My linear actuator has limits up and down.
Servo City has a wide range for any requirements, 2" to 12" stroke, speed and strength as you want. No extra electronics needed. They cost 300 $.
While you guys are pouncing - find out if he has the actuator because it was free? It’s a 12volt one, so I assume it’s quite heavy duty. Might be worthwhile to ask some questions and explore what he’s got and why?
I do agree, if there’s an option to purchase a correct actuator for the application... if that’s part of the plan. But, if you came across this actuator currently in your possession for much less than a new $299 purchase, it’s going to be more cost effective to retrofit.
If 1" height is all you need, be potentiometer will do that, it’ll simply need a larger diameter wheel on the end. Or, you can look into getting a multi turn potentiometer from digikey - that’s the easiest and most robust solution.
#15
I use to use a cable potentiometer on machines I built. Think of a retractable tape measure and how it works. Put a multi turn potentiometer in the middle of the drum and you have the concept.
Use a couple of pulleys to go around corners.
They work great for position feedback.
