Hello,
I want to merge some example scripts into my project and I cannot find where they are located on the hard drive. Path please?
EZB Connections
— Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
Hello,
The examples are not in a folder, you will need to save the example to the hard drive first. Then you can merge the saved copy.
