Aimlbot icon Aimlbot — Localized AIML chatbot with editable AIML files, ez-script support, session memory and ControlCommand API; integrates with speech and robot skills. Try it →
I believe xBee is longer range. Beyond that things get expensive ie, WiFi/4G mobile hotspot on your bot from one of the cellular providers could give you access over the internet, but has a monthly cost - also need to find one that supports port forwarding so you can tunnel through it to the bot unless you also have a PC on board running one of the remote control applications that can publish their location from behind firewalls.
You can use some of the Xbee modules like THIS Xbee, they can operate up to one mile.
I am using an Air Cable RX3 Blue Tooth extender. Doubles range for me.
Alternately, and I don't know if it's as popular over there as it is here but some ISPs use a second wifi radio in routers to broadcast a public network. BT OpenZone is one over here. Great coverage where I live, I can use wifi on my phone almost anywhere.
So, add a netbook to the robot, have it connect to the EZB any way you like (BT, USB etc.) and then use the netbook's wifi to connect to these open wifi connections. Set up the server options and port forwarding, connect to the ARC instance on the netbook via the internet and voila, almost unlimited range.
Im thinking about using an onboard pc directly connected to the EZ-B using usb along with a good cell phone internet stick that will connect allmost any where but it will cost alot about 75$ a month for me where i live
I will wish to avoid using a system with 3g subscription. Xbee seems to be a good idea. Have you ever tried with the EZB controller ?
