Live Stream Broadcast icon Live Stream Broadcast — Broadcast live audio and video from ARC camera to the web via HLS; cross-browser streaming. Requires router configuration for external access. Try it →
Resolved Resolved by Jeremie!
Looking For Input For Relays?
I need to find a source for relays that folks have used. I looked up a few of the posts but unsure of a source for tested and working relays from say, Amazon. If anyone is using a relay and can chime in with a particular make and model would be great. I'm using an ezb to turn on and off 12v motors?
Set Digital by Synthiam
Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only.
Hi Will,
I've used Fotek solid state relays in the past, they've been pretty reliable in my experience. I like solid state relays much better than the standard electromagnetic relays.  The contacts inside electromagnetic relays can wear out and fuse over time and they always make a racket when rapidly switching. I like how silent solid state relays are, and they have no moving (mechanical) parts.
https://www.amazon.com/FUXU-SSR-100-Solid-Module-Output/dp/B07DL983Z2
Thanks Jer..that’s what I needed!
