EZ-Script Console icon EZ-Script Console — Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN. Try it →
Resolved Resolved by Athena!
MG995 Servos Not Centering
Hi Roboteers,
I've noticed that MG995 servos will not move to the center position or to any other commanded angle. I tested three MG995 servos (all purchased from Temu), and all exhibit the same behavior. It seems likely the problem is with the servos themselves. Any ideas?
Posting here on the Synthiam forum - if it helps, I can provide more details about how the servos are connected (EZB, separate servo controller, RC receiver, Arduino, etc.), which Robot Skills or scripts I'm using in an ARC project, and any other relevant setup information.
Vertical Servo by Synthiam
Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos.
Horizontal Servo by Synthiam
Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert.
A few things come to mind, and it may not be ARC if all three MG995s behave the same way.
First: MG995s are often inconsistent
The MG995 is one of the most commonly cloned servos on the market, and a lot of low-cost versions have:
  • poor centering
  • deadband issues
  • exaggerated jitter
  • weak/incorrect internal potentiometer calibration
  • counterfeit or re-labeled specs
If all three servos act the same way, that points either to:
  1. a common wiring/power issue, or
  2. a batch of servos with the same defect/clone characteristics
Most important checks in ARC / EZ-B
Since you're in ARC, I’d verify these in order:
1) Test one servo with a simple servo skill
Use:
Then in the skill’s kebab menu:
  • select the correct Board Index
  • select the correct port (for example d0)
  • set a safe Min / Max range, such as 60 to 120
If the defaults are both 90, the servo won’t visibly move.
2) Confirm the servo power supply
MG995 servos can draw a lot of current, especially under load.
Make sure:
  • servo power is not being pulled from a weak source
  • the supply is sufficient for stall current
  • ground is shared between the EZ-B and the servo power supply
If the servo is powered from the EZ-B port, and the supply sags, the servo may appear to ignore commands.
3) Check whether the servo is actually centered at 90
For cheap analog servos, "90" in ARC is only the commanded midpoint, not guaranteed physical center.
If the horn is mounted off-center or the internal pot is off, the servo may never line up exactly at center.
4) Try a direct script test
In ARC, try a simple JavaScript test:
Servo.setPosition(d0, 90)
sleep(2000)
Servo.setPosition(d0, 45)
sleep(2000)
Servo.setPosition(d0, 135)
If there’s no movement, that’s a strong clue the issue is wiring, power, port selection, or servo failure.
Common MG995-specific issue
Some MG995 clones don’t behave like a true 180 servo. A few are:
  • mechanically limited
  • poorly calibrated
  • continuously jittering around center
  • unable to hit precise midpoint
So "won’t center" can be a real servo quality problem, not just software.
What I’d like to know
To narrow this down, can you share:
  • How the servos are powered
  • What board/controller is driving them (EZ-B v4, Arduino, servo controller, RC receiver, etc.)
  • Which ARC skill or script you’re using
  • Whether the servo:
    • hums but doesn’t move
    • moves to one side only
    • jitters near center
    • works manually but not in ARC
If you want, I can also help you build a clean ARC test project to verify whether the issue is the servos or the control method.
@athena
problem solved . i used two talk servo windows . a V2 and a V4 . i didn't need the V4 talk servo . thanks
