PWM Servo Ramping icon PWM Servo Ramping — Smoothly ramps PWM servos on EZB D0-D23 via Vx-to-Dx mapping for natural, gradual motion without snapping. Try it →
Twitter
MJPEG Stream in Camera
MJPEG Stream In Camera
I am using the ESP32_CAM with a camera stream for MJPEG files.  Code here.  https://github.com/arkhipenko/esp32-cam-mjpeg It runs fine and shows a 320*240 image when I bring up a browser or VLC.  I open the camera control and type in the URL of the stream it generated https://my.cam.ip.xxx/mjpeg/1 (The same one I use in VLC) and the camera initialises but doesn't actually open (The virtual camera lens stays closed) . Anyone else stream mjpeg cameras in? The manual hints there is support.
ESP32 Cam by Espressif
Servos Varies
UART Varies
ADC Varies
Digital Varies
Twitter
see my note above   You don't allow http on your server copy paste links
Twitter
I mounted ESP in the palms of my robot hands so I can see what I want to pick up.  Works well but now I need the robot to see it to use object recognition and rotation angles your wrote in order to pick something up.  Think I need to add a distance sensor as well
Twitter
Wow thanks DJ.  I must owe you half a dozen premium support tickets in the past month now.
thank you so much.
Twitter
Plugged in Camera and ESP picture quality is really good for a $9 camera and responsive.  I was surprised. The MPEG Stream I was using was jittery and delayed. Any hints on mapping of GPIO ports to Dx ports. Its tricky finding a free port with the camera enabled.  So far I haven't found one that I can drive a servo from. Looks like the camera consumes a lot of the GPIO ports and they are the same ones that are mapped to pins.   GPIO12 13 14 15 2 and 4 look like they are reserved for camera.  I tried to use GPIO16 (I assume from ESP code that mapped to D13) but enable D13 causes ESP13 to crash.
I thought I could take TX and RX as they are not really needed after you are connected and I won't have FTDI enabled in bot. These are GPIO 1 and 3 according to your diagram but I am not sure of Dx ports they map to as they are not on the original ESP diagram.
#14   — Edited
Re: gpio in ezb connection see conversation in this firmware thread: https://synthiam.com/Firmware/ESP32-Cam-EZB-5KUNP4UTSW0
i also removed "live stream receiver" robot skill from being tagged in this question. The "live stream receiver" robot skill was not being referenced or used in this question. Unless you had a specific reason for tagging it let me know and I’ll restore it?
