EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Resolved Resolved by Jeremie!
MPU9250 All-In-One Compass/Gyro/Accelerometer/Temperature Sensor
The MPU9150 EZ-Bit module all-in-one Compass/Gyro/Accelerometer/Temperature sensor it has been discontinued. Where or how I can get the MPU9250?
MPU9150 ARC control reads compass, gyro, accelerometer and temperature via I2C, initializes and sets EZ-Script variables on demand.
Hello @jorgelastra1,
Back at EZ-Robot, when we were selecting Hardware for an IMU sensor we started development with the popular MPU9150. Unfortunately, right after we completed the design the chip manufacturer, Invensense, made it obsolete without warning. The world's supply of MPU9150s was gone in less than 6 months. We moved onto the MPU9250 and developed the code for it but it wasn't the same form factor of chip so the board had to be entirely redesigned. EZ-Robot didn't end up remaking the hardware because we lacked faith in Invensense. We moved onto using an IMU chip from STmicroelectronics, and the design was completed and opened up by Synthiam last summer, see here: https://github.com/synthiam/E-43_Inertial_Sensor. You could make your own if you'd like.
I believe that EZ-Robot was still planning on manufacturing this board but I would get in contact with them to see if that's still the case.
#2   — Edited
Thank you for the Information - I would like to know if EZ-Robot still planning on manufacturing...I would like to get one!
#3   — Edited
hi jorgelastra1
ez robot is no longer from dj its sold.you can conact ez robot and ask them. there is also a notification button on there site. dj does only sofware now.thats why it called synthiam arc ez robot sensor
