Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
Make Tutorials For Ez-credit
Make Tutorials For Ez-Credit
Hello!
You may have seen the new tutorial section, and it looks like we already have a bunch of new tutorials. What we need is more tutorials, so I have created a list of tutorials below for anyone to take on. Just respond to this post with the tutorial you would like to create and get started. If you have any suggestions for other tutorials I can add them to the list as well. Upon completing the tutorial, you will be rewarded with the ez-credit value listed with each tutorial!
Some of these tutorials will be very simple, but keep in mind, it will be helpful for lots of new users.
EDIT: When you are done making the tutorials please make a post on this thread letting me know you are done. That way it will be a bit easier on me to keep things organized. Thanks!
IMPORTANT Credit must be given to any information obtained from 3rd party sources
Tutorials:
Controlling a Neo-Pixel ring with the EZ-B v4 and an Arduino - $20 bhouston Completed
How to connect and use multiple EZ-B v4s - $25 thetechguru
Speech Recognition - $10 Steve G Completed
Setting servo speed, and initialization scripts (Using the connection established command) - $10 Steve G Completed
Serial (Explanation of what it is, EZ-Script functions, peripherals that would use it, etc...) - $15
UART (Explanation of what it is, EZ-Script functions, peripherals that would use it, etc...) - $20 Richard R
i2c (Explanation of what it is, EZ-Script functions, peripherals that would use it, etc...) - $15
ADC (Explanation of what it is, EZ-Script functions, peripherals that would use it, etc...) - $15 Steve G Completed
Looping (Using repeatuntil, repeatwhile, goto, etc...) - $10 Richard R
Files (read, write, etc...) - $15 JustinRatliff Completed
Arrrays (Explanation, functions) - $15 Ravdeep Steve G Completed
Pandorabot - $20 Steve G Completed
Using a LIDAR with the EZ-B v4 - $15
Amps and Volts (Current draw, voltages for different peripherals, voltage regulators, voltage on pins, etc...) - $15 Steve G Completed
Battery choices (Different types of batteries and what to use them for) - $20 Ravdeep Completed
Power supplies (I believe that @Technopro has a thread on this. Maybe he wants to create a tutorial for power supplies using that thread) - $20 Technopro Completed
Sabertooth/Kangaroo - $25
Tip120 & Tip122 Transistor Switching Circuit Steve G Completed
#89
@Steve That looks great! Just one thing
Quote:
[b9.)[/b] Save this script, and now you are ready to test it. Press "Start" on the "Play Music" control and your audio track will begin to play. To stop the track from playing, press "Start" on the "Stop Music" script.
You got something weird going on here with your bolding.
#90
Oops. Missed a bracket. Fixed it.
Thanks.:)
#92
Thanks Dave.;)
#93
Hi James.
Just wanted to let you and everyone else know that I put together another tutorial... well it's not really a tutorial.
I spent the day C/P-ing the EZ-Script manual so we can have an online version to reference. I reformatted it so it looks the same, and also broke it down and rearranged it in to alphabetical order to make it easier to look for something. There used to be a copy of the manual on the website but has since disappeared. I for one used to use that a lot when using my phone (I know others used it too), and was surprised to see it was gone. On thing I noticed, there are a few spelling errors for the word "shield" in the ARC manual for the MP3 commands and thought you and DJ may want to know.
I will keep my online one maintained and keep an eye on DJ's release notes for any changes, which I will add or edit in the manual where relevant. I've also reformatted the dates in all of my other ones. Justin picked it up and I think he made a good point.
Anyway, I'm taking the weekend off to get over my RSI:P, and get back to robot building next week.
The EZ-Script Online Manual.
#94
If no one claimed it, I will to the power supply tutorial. Yes i made a thread about it.
#95
@Steve, nice work! @Technopro, I'll mark you down for that tutorial.
