MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Maker Bot Replicator2 X
I have an opportunity to obtain an makerbot 3d printer. I have zero experience with any type of 3d printing whatsoever. Does this tool come with software to design the piece or does it require a program like autocad 3d or solidworks to design and then convert to machine code? Thanks for any help!
                                              Chris
Trinidad/Tobago
Twitter YouTube
Generally I use Solidworks to create the 3D model. I then have to use MakerBot Desktop Software to import the model from an STL file. Finally, within makerbot's software you position the model in the print space correctly and then export the print.
I don't think makerbot gives you software to create 3D models with but I can be mistaken.
You would use something else to create the model. There are many 3d apps out there you can use. Some are more robust and complicated than others. Just depends on what you are comfortable with when you use it and what features you are looking for.
I am not sure the MakerBot 2x is a good starter 3d printer... It is listed as an "experimental" printer ... I would assume for advanced uses... I just bought an UP! Plus 2 3d printer and it is very good for the first time user.... I also have my eye on a Flashforge Creator Pro which I may break my bank and buy as well....
The FlashForge Creator Pro is a Makerbot 2x clone. If you do go that route, check out this link for some performance improvement ideas.
FlashForge mods
The FlashForge Dreamer looks good from the videos posted.
Also, if you are looking at that, there is a black friday deal from Micro Center for a flashforge creator clone that is selling for $800.
Flashforge Clone
@d.cochran.... thanks for the clarification.... I am already checking out that link about the Flashforge you posted....:)
The reason I am looking at the Flashforge Pro is I can get one for $1500 CAD... $750 cheaper than the Makerbot Replicator 2 and $1200 cheaper than the Replicator 2x (here in Canada)....
Agree completely. I can buy 3 of these for the cost of a makerbot and it is based on their reliable model from makerbot that EZ-Robot has 5 of. I wish the makerbot 5th gen was all it was supposed to be and I would go ahead and get one of them, but the smart extruder is giving them fits.
Makerware runs for flashforge and other clones also. Cura is also simple and easy to use. All of them are really simple. Slicing correct for your printer is the really important though and makerware does this based on specific makerbots. Cura has multiple presets but is designed first for ultimaker.
I really wish makerbot still sold the 2 but at reasonable prices. They pushed their last product to market too quickly. Corporate buyouts often have these results though. This has defiantly hurt makerbot in the short term. I hope there is a long term benefit to them though.
