UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Maker Faire 2013 Nc, Usa , Ez Robot Booth
https://makerfairenc.com/
We have been disussing setting up a booth area to show off our robots and also have a small airsoft robot arena to battle in;) So far we have Bret , myself and Alequa my brother coming. I made this thread so we are not discussing things off topic on others. Here is trossens arena for ideas but we can make ours different.
#17
Josh, how big do the fake buildings need to be and how many of them?
#18
Right now we are looking at 4 buildings and I believe 30 inches is more than enough for building height. Im really glad this is going to be indoors so that weather does not play a serious factor in what we need to bring to have a fun and presentable setup..
#19
What about Balsa wood for the building material? Balsa wood panels could be cut to size, painted, & transported; then put together fairly quickly with hot glue, onsite.
#20
Well balsa costs lots of money. Maybe home depot 1/8 plywood or something can be used to make panels.
#21
I was thinking of that foam core poster board.
#22
Do the streets need to be wide enough for two bots to go down them side by side, or one bot to go down them with a little room to manuveur?
#23
Streets must be large enough for two bots to pass each other without hitting. That should reduce how often bots hit the buildings lol.
#24
I've decided just to use heavy boxes as buildings and paint them to look cool lol. This weekend I pick up pcv to start framing everything. I plan on bringing 3 tables to display robots and one table specifically for laptops to link to the air soft robots in the arena area. Anyone have suggestions. Is there anyone besides me , Bret and Alequa going to make it? We would love to have you.
