Rplidar icon Rplidar — Slamtec Lidar driver for ARC; scans 360° and publishes distance data to NMS for mapping, obstacle avoidance, and navigation. Try it →
Makerbot Clones
Makerbot Clones
I think it's probably about time I tried printing some of the 3D parts I've been creating for the last couple of years (there are a fair few of them, I just hit a big milestone with the number of "things" I've created) so it's time to look at 3D printer options.
There's no way in hell I'm about to be able to afford a Makerbot Replicator 5th Gen since over here they are a minimum of 2,000 + VAT (20%) + Shipping so we are looking at around 2,500 ($3,800) if not more - now you know why I'm hesitant about 3D printing!
Makerbot "clones" on the other hand are a great deal less expensive. I appreciate that the components and construction will be lesser quality than the official Makerbots however we are looking at a 2,000 difference so the clones are extremely tempting (although only from a source which comes with great feedback and support, so probably more like 1,500 difference)
But I'm not naive enough to believe a clone is as good as the real thing so am reaching out to anyone who has experience in using the clones for any advice.
Yes, a makerbot would be the wiser choice but not for one who cannot drop 2,500 on concepts which may never have any return on them at all.
Alternatively, I have the option of the following 3D printers which do fall close to my price bracket...
Cube (2nd Generation) - 140x140x140 print area, 200 micron finest print. XYZprinting da Vinci 1.0 - 200x200x200 print area but stuck using their filament (unless "the people" did find a hack). 100 micron is finest print.
The da Vinci is the one which is tempting me most, especially if that hack is available (I'll search soon). But at 20% of the price of a MB Rep 5th Gen it's screaming out that either MB are darn expensive or it's not going to be much more than a paperweight.
Help... stress (Ideally by saying "I have a da Vinci 1.0 and it's awesome once you do this and that and tweak this")
#25
3D printing is its own beast that you have to tame before parts come out like you want them to. If the robot is small, you might check out the UP printers. There are a few people around here that have had really good success with them.
Once you get into 3D printing, you soon find yourself designing your own stuff which takes it to a completely different level of fun.
If you are looking to print a single small item, services are much cheaper in the long run. If you decide to make multiple items it quickly becomes cheaper to buy your own printer. I couldn't even begin to imagine what a service would have charged for all of the 3D printing that I have done over the past year and a half. I suspect that it would be more than the ~$2500 that I have spent on printers and filament though.
there isn't a common opinion which printer is affordable, easy to use, trouble less, etc...
so my only solution is an online service...
  1. can someone recommend a service ?
  2. I would like to print DJ's new EZ-BIT, i had some issues before the printed parts (clips) not fitting, did happen to someone else too ?
#27
As I said Shapeways worked fine for me...was by far the cheapest online service! I will work with them for now, I might check other options too, but they seem to have a good service and a nice variety of materials to choose from!
I would love to have a printer too, but I am kind of scared to invest in the wrong one....I might have to do a bit of research soon!
@CochranRobotics my aim is definitely to create my own robot, that was what exited me when I found EZ-Robot, I am still a little unsure about the different data formats and am kind of scared to miss some open edges or flip some verts buts I guess I can tackle the beast!
#28
Quote:
Safeways
Auto-spell check error. Shapeways is what he meant.
Hahaha...thanks Alan, was actually my brain on auto pilot!:D
Would be kinda cool though if you could shop your 3D prints at Safeways...lets just wait a couple of years!;)
#30
Some Staples office supply stores have 3D printers, so yes, it probably won't be long before this is much easier and cheaper. And of course the home machines are getting more reliable and eventually will just be another appliance.
I had a DaVinci, It worked well for almost three years. I was limited to there filament and I didn't like that, so I got the reseter. It didn't always work properly. I finally flashed it with Repetier as I saw on you tube. I was able to use any filament brand. You just have to set the settings properly. Lots of tinkering to find what works best for you. I also had a CTC printer. It worked good as well. But I ran into a lot of problems after about a year, with broken wires , and spent a lot of time upgrading it. Nothing hard to do, but time consuming. Also the print bed is smaller than a Replicator 2. I also tried an i3 Prusa. It's simpler when it comes to repairs, everything is at hand, and in the open. I got great prints at first, but after only a few long prints, it isn't printing very well. Only had it about 2 months and hardly used it. I was able to get a makerbot 5th cheap on E-Bay. I've gotten some great prints from it. However, I have also ran into problems with filament jams, ( which I was able to find the cure for from Makerbot) and problems with the base layer coming out very rough, ( haven't cured this yet). All in all, It hasn't been a bad printer, and prints larger that the Davinci. It is noisy though. Also, it is recommended to use PLA filament only, on the 5th. You can print in ABS, but it doesn't have a heater bed. The Davinci, was much quieter. As an entry level printer, it was great. It is a large machine size wise. I recommend it as a beginner unit, if you have the space to put it. Otherwise the CTC was a good starter and cheap as well.
#32
I saw a printer at a trade show. It was just a robot arm, but you could change the things on the end of the arm. It started with a wrist and hand and wound up a 3D printer. The things were changed again and it was a Laser cutter. It was also an engraver, Drill, and other tools. It was in one of these kick-starters. But it was Amazing! And, it was reasonably priced.
