Irobot Roomba Movement Panel icon Irobot Roomba Movement Panel — Control Roomba/Create via ARC: drive, stream sensors, read encoders, configure COM/HW UART, and send pose to NMS for mapping/navigation. Try it →
Netherlands
Twitter YouTube
Hey DJ,
Is there a map feature in ARC?
I have a voltage divider setup to measure the battery voltage and i would like to show the voltage on my Omnibot's LCD.
Now the value is 0-10v in stead of 5v so i would like to map the ADC value from 0-255(is 255 the max value of the EZ-B?) to 0-10v.
The ez-b cannot accept any more than 5v. You can build a very simple voltage divider with a resistor. There is a post on here somewhere about doing that. If you give the adc more than 5v, it'll pop the chip.
There are details in the manual:)
Netherlands
Twitter YouTube
Look at the 3rd paragraph,
I AM using a 1/1 voltage divider to measure up to 10v,
But then if its 8 volts, the EZB reports 4v. Now im looking for a script command to Map the values and send them to my LCD over serial.
