i am redo my mecca robot.am going to ad some more movements. like turning waist and bending.he allreddy learns how to trow a ball.hehe
— Edited
6 Participants
ZAMA Emotion Model
— Valence-arousal emotion engine generating persistent, configurable robot moods and event-driven emotional outputs for expressive behaviors.
thanks digiEddy .
am uploading a video now from high trow.
here a video for trowing high ball.its not always the speed that trows the ball, far.i notest at speed 15 he can trow far also.
i am waiting for parts ,so i kil my time do some experiments with ez robot, parts.also i have my first lotiny today.i can see now how much they come, in handy.so smal.very usefull.do the speaker is very quit.
okay i have now ad the arret for the turning plate.so that it doesn overturn, the body backwarts.now back waiting for parts.
a little update.mecca gets his speakers x2
here is an update for the mecca turning waist.i need some heavy springs . i used 2 meat boards with a grove in and some ball bearings 10 MM here is a little video and some pics.center bolt and wacher and locker 12 MM i painted two layers on,used and some grease.i also reinforced the back side. i notest the wheels are not straight .i used a alu plate 2mm
here a little update. for now i have some turning waist ,not total as i though, it would be.but for such big robot ,it is save not to go to the max of bending, and turning with plastik from a meccanoid.due they are very thin. also he will get a second HDD in the front for the bending,these two servo, are going to connect on the same port wiht a wire for two servo's. that means bolt will do desame movement at same time.this is needed , if you use bending&turning at same time.
That is freaking cool!
