Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
Meccano Rebuild
How to program a Meccanoid using ezb v4 with ez HDD servos? Some codes examples would be appreciated, thanks
#1   — Edited
hi
use the ARC off roli . same way as you would program a jd robot . you have to use all servo from ez robot in the meccanoid robot . they are same size . use a H-brige for the wheels from the mecanoid . witsh meccanoid do you have ? and are you going to use the ez robot camera?
