HT16K33 Animator (8X8) icon HT16K33 Animator (8X8) — Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control. Try it →
Meet The Smart Saltwater Aquarium Powered By Ez Robot
Ez Robot community I wanted to introduce my latest application of this system. Some members hear already know I keep two salt water aquariums one coral which unfortunately died off and my predator tank. Sea life needs delicate balance maintained in their little ecosystem. Things like light spectrum , temperature, ph balance , current of water , nitrate and ammonia levels and calcium levels. These things take a practiced hand to maintain. I am building a new system and using ez b to monitor salinity, nitrates and ammonia, temp , water current flow and the ph. The ADC ports are useful for these and EZ board can control the current and switching to a backup power supply ( a apc for computers inside the cabinet to keep ezb and pumps powered). Also the ezb can turn on and off night , morning , day , and evening lighting settings. With a custom injection device im designing ezb can provide nutrients , calcium and even medicine if levels are out of wack. I started the build today and I am very excited!
#273
Ok I will rewrite the script tonight and give it another go , this is a development so additional features will be addes in. One very important feature I must add is a reconnect script. I turned off Bluetooth power management and power management policy in windows and disabled usb power management but every few hours it may drop Bluetooth connection. Anyone have autoconnect ideas;)?
#274
I'm looking to sort out an auto-reconnect solution for my bot, I haven't done anything about it yet but once I have I'll let you know.
#275
JOSH are you adding temperature monitor to your saltwater tank design
#276
Yes , temp , salinity , water level alerts , and nitrate measuring will be added in the next couple of months. Because living things depend on this system im adding in one feature at a time and testing as I go. Next features to be added are the alternating wave system when the aqueon pumps arrive this week and night lighting leds.
#277
ok thats what i am using in mine PH monitor ,temp water levels and salinity i bought already most of my sensors i need ,plus HUMIDITY sensors for my gecko tanks Need to buy a PH monitor tester to calibrate my PH sensor about $20 on ebay
i do have part # and where i got each sensor including water level sensor if you need them to help you out in your project
#278
Sure if you would post them with links and price that would be great , thankyou
#280
about the PH sensor it does need a small circuit and sensor its about $19
all other sensors easy to interface
But second idea is to buy a digital PH monitor and may be tap in the circuit with 0-5 volts out for ADC on EZB i will need to buy t of them ,its about $30,since might need for for calibration
PH monitor for fish tanks
all ther sensors under $4 except for humidity sensor and board
