Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Merge Button Not Working Correctly
Just to let you know,
Downloaded the new version, and when I click on the Merge button, it opens the same window as the Open button does. It does not open to the correct screen.
I reinstalled, and it does the same thing. I am using Windows 8.
Everything else seems to be working so far.
Thanks, John
I have windows 8 and it works fine for me.
Selecting Merge opens the "Open" window because you need to select a project to merge. After you select project to merge, the Select Controls window will open and you can choose which controls to merge into the open project.
Did you actually select a different project or did you stop after the open screen appeared?:D
Ah, I see,
Yeah, I was thinking the select controls opened first. Sorry about that.
Thanks McJeff0125
