HTTP Server (Custom) icon HTTP Server (Custom) — HTTP server for ARC serving HTML/CSS/PNG/JPG from ARC/HTTP Server Root; supports AJAX tags (ez-move, ez-script, ez-camera) to control the robot. Try it →
Metadata File .Could Not Be Found
Greetings Kindered Robotists, I am trying to run the "hello world" c# example and its returning Line 0 "EZ-Builder.exe cannot be found" and EZ_B.DLL could not be found. This error is returned in MS Visual C# as well. I have not removed the Dll file or the .exe file nor have I changed the directories. Why cant the system "find" it. Prior to the disapearance I was working\experimenting with C# to "reinitialize" the Speech Recognizer as it "freezes" frequently and ARC must be restarted to revive the Speech Recognizer. Oh dear! What have I done? Your help would be MOST appreciated! Glen ,from Salt Spring Island
I got that message when working with my speech recognition before. But, it was many versions ago. I still don't know what happened. Maybe you could reboot and clear the memory or something.
@irobot58 I think you need to copy ez-b.dll and ARC.exe to your documents/ARC directory (where you *.ezb files are normally kept).
