Servo Summary icon Servo Summary — All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit. Try it →
Could i use the same motor with a driver already installed like the attached link and be able to hook straight to ez b without having to use the h bridge
motor with driver
It appears to emulate a 360 servo, so it should work. I have never heard of anyone trying one, so you may be the first. However, other than having a longer shaft, I don't see much advantage to it over a 360 servo. The spec sheet is incomplete. It gives the gear ratio, but not the rotation speed or torque of the motor so difficult to do a direct comparison.
reading the specs yes.
relevant information: Operating voltage: 3.5V - 8V Clockwise pulse width range: 500us-1400us (500us speed maximum) Stop pulse width range: 1400us-1600us Anticlockwise pulse width range: 1600us-2500us (2500us speed maximum)
behaves like a continuous servo, although the pulse range (500-2500) is not 100% compatible with the EZB V4 range (560-2140), you can still hook to one of the EZB's digital port (0-23), the only limitation is the top speed.
you will need to do some tests to obtain the stop position (middle value e.g. 90)
servo position 1 will be max clockwise speed
servo position 180 will be max anticlockwise speed
i agree with Alan's opinion, the shaft can be a problem,
you have better chances with a continuous servo:
https://synthiam.com/Shop/AccessoriesDetails.aspx?prevCat=104&productNumber=1307
the reason i am wanting to use this over the continuous servo is due to the design and size for a specific use where the continuous servo will be to large also by using this type of motor with the gearing in the way i want to implement it will give it mor strength as well. If all i would lose is a little top speed im perfectly ok with that. I will be going with a different driver that doesn't sit the way the one in this pic does or i will try to modify that driver and re solder it to a different location
if you plan to use a motor or a continuous servo, what kind of feedback circuit you plan to use ?
I was just hoping to be able to plug them in the ez b same as i did the regular 180 degree servos and make them work. send them a signal and it moves to the set position i put in. basically i make prosthetics for people who need them so i will be making this work in a hand there will be one of those motors for each finger and want to control it with the myoware muscle sensor and with speech recognition. if you go on my facebook page and scroll down to where you see me using the ez b I want to use the motors listed above in the same way i am using the servos in the videos on my FB page. obviously will work differently being the style of motor but just want to plug in ez b set the motor postions to where i want them to move once it receives a command
www.facebook.com/jbrawley127
