Camera NMS Pose icon Camera NMS Pose — Overhead camera tracks a glyph to give precise robot pose to ARC's NMS for multi-camera indoor/outdoor navigation and waypoint control Try it →
#17
count me in as well for a mini EZ-B ! My project is expanding and needs more Digital IO's:) Dang 5 fingered hands,wrist,elbow etc!:)
#18
hey guys*** i just want to thank all of you for reply and i want to ask how i make wall e talk (i don't want to enter the computer be part in to make wall e to talk) so how !? blush
#19
This would be something to post in a different thread as it doesn't have to do with the ez-mini topic.
Way one: mp3 trigger A little device that can be wired up to the ez-b to trigger sounds from an Sd card.
Way two: PC wireless speaker Bluetooth speakers are very popular right now. Find one small enough, if needed take the shell apart, and set it up in wall-e where ever you want. Then just wirelessly connect to it from your computer and bam! Done!
Hope this helps.
#20
thanks but can i use easy vr (arduino shield) to ez b
#22
Arduino shields are compatible with EZB but not supported. Shields will not stack like an Arduino to Arduino Shield will. You will have to figure out how to mate them together and interface. You may have to remove those off two sided headers with the long pins on the bottom and sockets on the top and replace with a regular one sided header and use jumpers. Or you could just cut the lower pin and use female to male jumpers between the boards. I'm sure there are members here that can help you figure it out but I've never done it.
