EZMQTT Broker icon EZMQTT Broker — Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients. Try it →
Mini Itx Cheap! Dell Atom 330 29.99
Asendtech has several of these tiny 6 in x 6 in mini pc / CPU combo , just 29.99 , very very good option for a autonomous robot (a person doesn't need to be at a computer or laptop wirelessly controlling it ). These draw about 12 watts. I just bought one , get them while they are hot! - Josh
#49
if you dont use any video,or cslu animated face, and double check if its a dual core 330 processor since does take both and some come with it,memory just little low i can look for another one,but i do have one at home havent tested it yet reallly need 2 gig or more 1.6 mhz is ok on speed,so thinking it might work is dual core atom 330
BC is is one dual core 1.6 mhz up to 2 gig ram,i have one at home running LEAF low power ,just add 2gig of ram
1.6 ghz up to 2gig ram
#50
robotmaker, The processor chip has 512/533 on it. So I guess I will just hold on to for now but I will not use it. I will keep looking for the right board.
Thanks.
#51
1.6 mhz or more 2gig to 4 gig will work,i have another lapto using 1.6 ghx and 2 gig ram and its running fine i would under 3 ghz and 4 gig ram manly because others will much current that 512/533 is not the speed ,speed on that board is 1.6ghz that is the cache and memory speed
#52
512mb is onboard memory , 533 is MHz of memory bus I do believe , but there are lots of Intel atom low cost mini itx boards out there.
#53
yes that is correct,was looking something else because he said processor ,board takes up to 4 gig of memory
BC i look at the specs again that is a perfect board for LEAF ,JUST ADD 4 GIG OF MEMORY person selling that board does have it wrong ,there is no 512meg of memory installed just need to ask a question to make shore it does have ATOM 330 ,some with same model number has a ATOM 230 witch is a single core check page 2 of this post i have FX160 specs
#54
robotmaker, I called the company that I got the motherboard from and asked them if it had an INTEL ATOM and what the model number was (230 or 330). They told me it was a INTEL ATOM but they did not know what model it was.
I am still having problems with Leaf vision but I will ask about that on the yahoo group.
Thanks for your help. BC
@ jstarnel, thanks for the information.
BC
#55
BC its not the model # ,its processor # ,ask if its dual process or single processor if not there many other FX160 that ebay has that has dual core have the same board ,but had to double check to make shore it was a dual core processor
#56
robotmaker I found out that it is a ATOM 230 and that is a single core processor.
Thanks.
