Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
nope. they are different servos:)
Thanks DJ. Good to know. Are the servos you linked to above the ones used on JD's head? Will the brackets still be available or will you be replacing them with an ez bit?
