Ultrasonic Collision Detection icon Ultrasonic Collision Detection — Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling. Try it →
Hello, I can not seem to find where you enter the servo tweaking configuration file so every time i try to connect directly with a tablet none of the commands work correctly as the robot always is reset to an alternate android configuration file and with the changes in tweaking the robot slips or jams depending on which instruction you give him
i would also know how you could create scripts on the tablet, for customers that only own a desktop and do not have a laptop to connect with.
i have the DJ Robot
Thanks Richard
Foxtrot, those features are currently only available on the Windows PC version - The android version is being updated for servo Calibration.
As for editing and creating scripts on a tablet, there are no plans to allow that to happen as the file size and development investment would take over a year to port ARC to the Android OS. Instead, you create apps in Windows ARC and save them to run on the Android OS by following the instruction tutorial.
thank you for the information, i was more looking to do quick modifications to the script txt only, changing timing on sleep commands and such
also this doesn't explain how i ass the servo configuration file to the android tablet. currently it can not be used with anything but a laptop as every time i connect with a tablet it does not have anything but the project and can't fine tune the servos causing all the commands to fail
As I said, the android version is being updated to include the servo configuration - as it isn't done yet.
ok thank you, so currently there is no way to use anything but a laptop to use the robot until this is fixed? and how long until it will be fixed?
by the way i am Richard Donovan i have called before, i am working to set up hobby and toy centrals robots and they plan to use tablets to demo the robots so i could really use a solution asap as its a toy store and handing children a laptop would be to risky.
sorry for the inconvenience and your help is appreciated
FYI, the latest ARC for Windows and Android support servo Profiles saving to the cloud
We have a little under a thousand items on the list to be added - you will see many features added often. Monitor the Release Notes for additional features that are added
