Single Camera Servo Server icon Single Camera Servo Server — TCP video server for Unity clients to stream camera video and send servo positions to ARC for remote robot control Try it →
Mixing HDD and HD servos
Mixing HDD And HD Servos
What happens if you mix HDD servos with HD servos in your robot? Will only the HD servos jump around or will others move inadvertently too? Thanks.
#9   — Edited
Jeremie:
Quote:
That's correct, only the HD servos will move on initial power up the HDD servos will not move (they have a completely different internal electronic design).
So the problems at startup are likely caused by power on and control floating for a few seconds, the analogue servo will interpret the voltage floating as impulses and will try to match with the feedback from the potentiometer, so you ll see the servos moving without "control".
With digital servos, they don't move until the controller sends pulses.
It's possible to mitigate the problem (Analog servos) using a different power source (not from EZB vin), controlled by relay (a good one with enough Amps to support the servo inrush) and using the relay Normally Open position, so when you power the Robot, the servos will not get the power, then you have plenty time to EZB to boot, Windows, ARC, initialization script to initialize all servos to the initial position. When you are ready, you enable the relay, so the servos will get power and logic control at the same time.
Thanks to everybody. I understand. HD and HDD  are used by ez-robot servos. "Heavy-duty" is used for  digital servos. Hitec servs, for example, are simply  analog or digital, non such acronyms.
#11   — Edited
Not to be pedantic ... but "Heavy Duty" is the HD meaning, is common to analogue HD and digital HDD.
you gave a good example:
If you look well the Hitec's model HS-322HD uses the same terminology.
The devil is in the detail:)
btw: the Hitec descriptions are misleading. Has 2 Karbonite and 2 nylon gears and in light use they both break easily. It's not a heavy duty servo by any means.  EZ-ROBOT should change to SHD Super Heavy Duty:), off course not all HITEC servos are equal.
#12   — Edited
OK, PTP ez-robot :HD =heavy duty , HDD=heavy duty digital  Hitec : HD =it should be heavy duty but itsn't necessarily
