Once a project has been downloaded to your device, do you need the internet connection anymore? I ask because I saw a thread about a farmer wanting to use robots and he was given advice on router boosters and such but if once the project is on the phone then he could just get some smartphones and EZBs, download the project, connect the phones and EZBs via bluetooth and he's be good to go. No need to extend his wifi range or anything. Possibly the cheapest solution as well.
I just didn't want to recommend that solution until I knew for sure if that was in fact the way it worked.
Thanks in advance.
That's the way I thought it would work. Good info friend
Thanks Alan. I'll throw together a quick project and test that out. I'll post the results.
BTW Does EZ-Robot have a Rss Feed?
[update] While putting together the test project I found I have this problem. It will tweet but not read twitter. It reads Rss fine. Here's what I get on the console:
Start 1: Tweet("Testing the twitter account") 2: SpeakTwitter("AntronsRobots", 0)
Did twitter remove this feature? [/update]
