SMTP Client icon SMTP Client — Send SMTP email (text or camera images) from ARC robots via ControlCommand; configure SMTP/auth and sender; saves credentials in project. Try it →
Mobile App For Galaxy Tab 10.2
I created my first mobile app in builder. When I run the mobile app I find my file on the cloud ok and it appears to load but I just get a quick date flash at the bottom of my screen and it reverts to where I started. I tried several mobils from the public cloud and got the same result - nothing. I am running android 4,2,2 on a galaxy tab 2 10.1. Does this work only on a phone?
check the log and see what the loading error message is. The Android App works on all Android devices.
I just built my own mobile app, uploaded to cloud, and ran on my Samsung galaxy tab 3. This app is awesome. I was absolutely amazed at what this system can do. I cant wait for the rest of my part to arrive (camera) so I can do telepresence, and open up my router ports to be able to see from other networks. This is not meant as a post hijack,just plain excitement. It does work!
                     Chris
the log only has:
6/15/2014 5:48am - ARC Mobile v2014.05.24.00
at the top, I'm guessing the initial entry... after three tries at download then failed
Can you make your project as public and tell me the name? I will take a look:)
I could except I find I can't reload the project ("first App") on my PC, but I get a log that I uploaded as 1EZBlog.txt... Maybe you can see what is going on:
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 6/15/2014 11:44 AM - TCP Server stopped 6/15/2014 11:44 AM - TCP Server stopped 6/15/2014 11:44 AM - TCP Server stopped 6/15/2014 11:44 AM - TCP Server stopped 6/15/2014 11:44 AM - TCP Server stopped 6/15/2014 11:45 AM - NAudio.MmException: BadDeviceId calling waveInOpen at NAudio.Wave.WaveIn.OpenWaveInDevice() at NAudio.Wave.WaveIn.StartRecording() at EZ_Builder.UCForms.FormMic.(Object , EventArgs ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at .OnLoad(EventArgs ) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.SetVisibleCore(Boolean value) at System.Windows.Forms.Form.SetVisibleCore(Boolean value) at System.Windows.Forms.Control.Show() at .(ConfigurationFormV2[] ) at .(ConfigurationV2 , String ) at . (Object , EventArgs ) 6/15/2014 11:47 AM - NAudio.MmException: BadDeviceId calling waveInOpen at NAudio.Wave.WaveIn.OpenWaveInDevice() at NAudio.Wave.WaveIn.StartRecording() at EZ_Builder.UCForms.FormMic.(Object , EventArgs ) at System.Windows.Forms.Form.OnLoad(EventArgs e) at .OnLoad(EventArgs ) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.SetVisibleCore(Boolean value) at System.Windows.Forms.Form.SetVisibleCore(Boolean value) at System.Windows.Forms.Control.Show() at .(ConfigurationFormV2[] ) at .(ConfigurationV2 , String ) at . (Object , EventArgs )
I made a new mobile app, "First App - Rick" and posted it public. This one I can re-open in the PC but the tablet still seems to load it but doesn't and writes nothing in the log...
I could have really used the EZ-Robot stuff but if I can't get the mobile app to work then I'll seek an alternative. To Summarize: Installed both the mobile app on the Galaxy 10.1 and on my pc. The mobile seems to work ok, downloads show up in the local folder and the data reading shows that they are there. However, none of them will run in the mobile app. I'm logging off for the last time, if you discover the problem you have my e-mail... Thanks...
I think your doing it wrong?.... You can't run a native windows ARC project on an Android... You must create a specific mobile app for Android from within ARC (on Windows PC). In ARC select project/add/mobile.... Build the mobile app then uploard it to the cloud then download the app to your android....
