Graphy icon Graphy — Plot live data with ControlCommand scripts: multi-series charts, many chart types, legend toggle, add/remove series, export graph data to CSV Try it →
Mobile EZB And USB Connection
Is it possible for EZB-mobile have support for USB connection?  My robot has an embedded pc with USB connection at the moment, but I would rather use something smaller if possible.
I had problems, in the past, with WiFi dropping connection or struggle to gain connection in large crowds. I settled with an embedded computer for the last 1-2 years.
The robot is often out with large crowds so safety / dropping connections is the biggest concern.
Thank you for your input, Aaron
EZB Connection by Synthiam
Create touchscreen robot control panels with buttons, joysticks, sliders, camera views and scripts; multi-page fullscreen UIs for PC and mobile.
EZB Connections by Synthiam
Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
Com Port Manager by Synthiam
Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART.
#1   — Edited
The mobile ARC app internally only has code for wifi connectivity. It has no code to understand USB connectivity because it's non-standard or not compliant on most devices. It would be nearly impossible to write a single application that supports all usb dongles
There are a few things you can do
  1. add a safety switch to the robot to monitor wifi connectivity with a relay connected to the EZ-B. The EZ-B has a setting in the configuration interface which uses port D24 to determine the status of the connection. So the robot can have a shutoff relay when the signal drops. Look in the ez-b configuration to set the option.
  2. use a wifi scanner to get optimal wifi channel. I know on ez-robot's website they have a link in the FAQ about that here under WIFI SATURATION: https://synthiam.com/Tutorials/Trouble-Shooting.aspx#9
4) use a $25 raspberry pi in the robot running ARC instead of a mobile device
Hi DJ,
Thank you for the response.  Understood that the mobile interface will not connect via USB.
I did not know that D24 was able to monitor the connection in this manner! I will setup my robot with this feature regardless of the operating system. [the robot weighs around 100lbs]
What would perform better in your opinion: -a standard pi[b+] utilizing ARC -a mobile app using a phone with 4gb of ram Are these two components comparing apples to apples?
Thank you, Aaron
the Pi version will give you more potential because plugins don't work on mobile. Also, with the Pi you can have more programs and different versions of programs. It's like having a little PC
Although, i do recommend Atomic Pi instead because it's $35 and runs windows. So it's just like having a laptop on your robot!
Atomic Pi is already sold out!!!
Thanks for the info!! Awesome find!!!:D
#6   — Edited
Hi DJ,
Thank you for the link and info on the Atomic Pi.  I am going to wait until the Atomic Pi comes back in stock.  I think this is the best solution for my requirements.
In the meantime, can you recommend a suitable relay for a 12V source? All of my robots will be getting this update.
EDIT Would this relay be acceptable? Relay Link:
Thank you, Aaron
this is a good question for Jeremie. I’ll tell him to check the thread
@robot56
12V automotive relays are definitely a robust option for switching 12V but personally I tend to stay away from relays. Relays are mechanical and do have a limited life. Automotive relays are definitely better as I have yet to have an automotive relay fail in any of my vehicles but I like to use MOSFETs instead. MOSFETs also don't have the electrical "ringing" effect of switch contacts and are audibly silent. There are a few caveats to using MOSFETs but there's tons of information online to sow you how to use them effectively. You can also purchase boards with the supporting circuitry already added.
Here's an example from Amazon
Due note that MOSFETs do generate a lot of heat with high current loads so sometimes extra heat sinking is required.
