UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Mobile Interface Combobox
Is there a way to use the selected value of a combobox in a script instead of the index?
I added a combobox to the mobile controller with a list of items. When I select the item I want to have the EZB repeat it. This is the groundwork for the robot to address people directly after their introduced.
Example: Combobox has 3 items. 0-What's your name? 1-Hayley 2-Mason
Here is my current script tied to the combobox.
if ($SelectedIndex = "0") SayEZB("What is your name") elseif ($SelectedIndex = "1") SayEZB("Hello Hayley") elseif ($SelectedIndex = "2") SayEZB("Hello Mason") endif
Is there a variable for the value of the selected item that I can reference instead of hard coding the names in the script? For example:
SayEZB($SelectedText)
Thanks in advance for any guidance. JP
