Twitter
Monitor PC voltage
Monitor PC Voltage
Anyone know of a good way to monitor power of the battery and feed voltage into ARC so I know when PC Is about to die?  I monitor Power of EZB but I can't monitor power PC has.  I share the same 12v battery for PC, Servo's EZB etc  but I keep voltage at 7.5v for EZB with a voltage regulator and for the PC I use a step up converter.  Step up converter starts to fail around 10.5v but EZB is still happy and doesn't record a voltage drop.  End Result is PC on robot dies without making it back to dock on time to recharge battery.
Note: I used prevent PC sleep as question but really it is pc shutdown due to no power.  I selected Rock PI X but using NUC but assume relevant.
Rock Pi X by Radxa
ROCK Pi X runs Synthiam ARCx as an onboard x86 robot brain for browser control, vision, voice, scripts and EZB I/O.
Servos ✕
ADC ✕
Digital ✕
Prevent PC Sleep by Synthiam
Prevents a PC from entering sleep mode via a tiny, resizable control-keeps the system awake while minimizing UI real estate
Twitter
OK Now I get it thanks. @DJ  I didn't realize you were proposing divide the voltage so it is less than 5vDC so the ADC could read it. @Proteusy thanks for the link to the Arduino code. that could work if it gets stuck and can't make it home in time.
Keeping a robot alive 24/7 is certainly an interesting problem.
Twitter
Thanks Question Closed.  Appreciate the help.
lol thank goodness. I was feeling like a broken record:D
while ironically listen to vinyl records as I type this...
Twitter
It worked well, I can even tell when I have docked correctly now as occasionally the magnets I put on the roomba and side of roomba charger don't contact in order to charge.  Sorry about the misunderstanding, I completely missed the read input voltage with ADC and was wondering why you kept wanting me to add a  voltage devider.   I will try the Arduino build later for a graceful shut down next.
#13   — Edited
There's a JavaScript call to shut down: https://synthiam.com/Support/javascript-api/Utility/shutdownPC
or hibernate: https://synthiam.com/Support/javascript-api/Utility/sleepPCHibernate <- Requires a lot of HD space and energy
or suspend: https://synthiam.com/Support/javascript-api/Utility/sleepPCSuspend  <- Requires battery still
But I think you'd want to use ShutDown. Because Hibernate should be disabled in your NUC for performance, energy consumption, and HD space. It's documented in the Storage and Performance tips: https://synthiam.com/Support/Install/free-space-with-windows-10
Twitter
Thanks.  I am adding a relay board to turn off with an ESP at the moment including cutting Roomba battery for emergency stop (need a big red button) and also clear up roomba when it gets stuck in program mode and won’t talk to EZB.  The JavaScript shutdown should work on PC. thank you then I can power off EZB say 5 minutes later.
still not quite at the point I am prepared to let it roam free yet but with the sealed lead acid battery, navigator, roomba dock, voltage monitor, object avoidance and auto charge, getting closer.
#15
haha yah it's super awesome watching the progress! Wish I had time to build robots like you guys - I'll live vicariously through you!
